CodiMD
  • New
  • Publish
  • Extra
  • Revision
  • Slide Mode
  • Import
  • Dropbox
  • Gist
  • Clipboard
  • Download
  • Markdown
  • HTML
  • Raw HTML
  • PDF (Beta)
  • Pandoc (Beta)
  • Help
  • CONNECTED ONLINE OFFLINE
  • New
  • Publish
  • Menu
    • Extra
    • Revision
    • Slide Mode
    • Import
    • Dropbox
    • Gist
    • Clipboard
    • Download
    • Markdown
    • HTML
    • Raw HTML
    • PDF (Beta)
    • Pandoc (Beta)
      Freely Editable Limited Locked Protected Private
  • Freely - Anyone can edit
  • Editable - Signed-in people can edit
  • Limited - Signed-in people can edit (forbid guests)
  • Locked - Only owner can edit
  • Protected - Only owner can edit (forbid guests)
  • Private - Only owner can view & edit
  • Delete this note
   owned this note
Expand all Collapse all Back to top Go to bottom
Import from clipboard
This note is locked
Sorry, only the owner can edit this note.
Reach the limit
Sorry, you've reached the maximum length this note can be.
Please shorten the note.
Import from Gist
Import from Snippet
OR
Export to Snippet
Are you sure?
Do you really want to delete this note?
All users will lose their connection.
This page needs to be refreshed
Your client's version is incompatible.
Refresh to update.
New version available!
See releases notes here
Refresh to enjoy new features.
Your user state has changed.
Refresh to load new user state.
Choose method
Sign in via CAS
Contacts
Report an issue
Meet us on Gitter
Help us translating on POEditor
Documents
Features
YAML Metadata
Slide Example
Cheatsheet
Example Syntax
Header # Header
  • Unordered List
- Unordered List
  1. Ordered List
1. Ordered List
  • Checklist
- [ ] Checklist
Blockquote
> Blockquote
Bold **Bold**
Italicize *Italicize*
Strikethrough ~~Strikethrough~~
19th 19^th^
H2O H~2~O
Underlined text ++Underlined text++
Highlighted text ==Highlighted text==
Link [link text](https:// "title")
Image ![image alt](https:// "title")
Code `Code`
var i = 0;
```javascript
var i = 0;
:smile: :smile:
Externals {%youtube youtube_id %}
LaTeX $L^aT_eX$
This is an alert area.
:::info
Revision
Export with pandoc
Select output format
